Motion Computing LE1600 Button Assembly Replacement
  1. Motion Computing LE1600 Button Assembly Replacement, Battery: step 1, image 1 of 1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Button Assembly Replacement: step 2, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 2, image 2 of 2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Button Assembly Replacement: step 3, image 1 of 3 Motion Computing LE1600 Button Assembly Replacement: step 3, image 2 of 3 Motion Computing LE1600 Button Assembly Replacement: step 3, image 3 of 3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  4. Motion Computing LE1600 Button Assembly Replacement, Button Assembly: step 4, image 1 of 1
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
  5. Motion Computing LE1600 Button Assembly Replacement: step 5, image 1 of 3 Motion Computing LE1600 Button Assembly Replacement: step 5, image 2 of 3 Motion Computing LE1600 Button Assembly Replacement: step 5, image 3 of 3
    • Pull clear plastic tab to detach hard drive from tablet.
  6. Motion Computing LE1600 Button Assembly Replacement: step 6, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 6, image 2 of 2
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  7. Motion Computing LE1600 Button Assembly Replacement: step 7, image 1 of 1
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
  8. Motion Computing LE1600 Button Assembly Replacement: step 8, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 8, image 2 of 2
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  9. Motion Computing LE1600 Button Assembly Replacement: step 9, image 1 of 1
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  10. Motion Computing LE1600 Button Assembly Replacement: step 10, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 10, image 2 of 2
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
  11. Motion Computing LE1600 Button Assembly Replacement: step 11, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 11, image 2 of 2
    • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
  12. Motion Computing LE1600 Button Assembly Replacement: step 12, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 12, image 2 of 2
    • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
  13. Motion Computing LE1600 Button Assembly Replacement: step 13, image 1 of 2 Motion Computing LE1600 Button Assembly Replacement: step 13, image 2 of 2
    • Remove the button board and replace.
Fred Wilby
65 Reputation
1 Guide authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,917
