Motion Computing LE1600 Battery Replacement
  1. Motion Computing LE1600 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Battery Replacement: step 2, image 1 of 2 Motion Computing LE1600 Battery Replacement: step 2, image 2 of 2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Battery Replacement: step 3, image 1 of 3 Motion Computing LE1600 Battery Replacement: step 3, image 2 of 3 Motion Computing LE1600 Battery Replacement: step 3, image 3 of 3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
David Troy
44 Reputation
3 Guides authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 2,746
