Mio Tab Lisciani Touch Screen Replacement
  1. Mio Tab Lisciani Touch Screen Replacement, Touch Screen: step 1, image 1 of 2 Mio Tab Lisciani Touch Screen Replacement, Touch Screen: step 1, image 2 of 2
    • With the help of a thin tool, lift the white edge between the upper body of the device and the touchscreen marked by the green arrows.
  2. Mio Tab Lisciani Touch Screen Replacement: step 2, image 1 of 2 Mio Tab Lisciani Touch Screen Replacement: step 2, image 2 of 2
    • With the help of a thin tool, separate the upper body from the bottom, inserting the tool between the two parts marked by the green arrow.
    • Open the device.
    • Remove the Scotch tape and disconnect the touchscreen connector by lifting the safety tab, located at the yellow arrow.
  3. Mio Tab Lisciani Touch Screen Replacement: step 3, image 1 of 1
    • Use a heat source to help remove the double-sided tape.
    • Insert translation here
To reassemble the device, follow the instructions in reverse order.
6 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,366 Reputation
39 Guides authored
3 Comments
Il tablet non si carica e non si accende e anche sotto garanzia. Come possiamo fare
Linda Cofone - Reply
Il tablet non si carica e non si accende. Come possiamo fare รจ anche sotto garanzia
Valuti di portarlo in assistenza ed avvalersi della garanzia. Saluti
Smilzo -
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,920
