Minolta QTsi Maxxum Shutter Button Replacement
  1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: step 1, image 1 of 1
    • Locate the battery compartment on the bottom panel of the camera.
    • Open the battery door by using a coin.
    • In the counterclockwise direction, twist the coin in the battery door groove to open it.
  2. Minolta QTsi Maxxum Shutter Button Replacement: step 2, image 1 of 1
    • Two batteries are located inside the battery chamber.
    • Remove the two batteries from the battery chamber by picking them up.
  3. Minolta QTsi Maxxum Shutter Button Replacement: step 3, image 1 of 1
    • There is a screw located underneath the batteries in the battery compartment.
    • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
    • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
  4. Minolta QTsi Maxxum Shutter Button Replacement: step 4, image 1 of 1
    • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
    • Be careful because you can lose the screw
  5. Minolta QTsi Maxxum Shutter Button Replacement: step 5, image 1 of 1
    • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
    • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
  6. Minolta QTsi Maxxum Shutter Button Replacement: step 6, image 1 of 2 Minolta QTsi Maxxum Shutter Button Replacement: step 6, image 2 of 2
    • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
    • Once all screws are removed, lift the top panel from the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  7. Minolta QTsi Maxxum Shutter Button Replacement: step 7, image 1 of 1
    • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
Jordan Ellery
388 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 7
All Time: 482
