Microsoft Surface RT Kick-stand Replacement
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: step 1, image 1 of 2 Microsoft Surface RT Kick-stand Replacement, Kick-stand: step 1, image 2 of 2
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
13 other people completed this guide.
Kevin Hua
1,615 Reputation
3 Guides authored
Cal Poly, Team 17-23, Forte Winter 2013 Member of Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Members
17 Guides authored
12 Comments
Where do you get the replacement kickstand from?
Ray - Reply
is this compatible with surface pro 1 ?
arqueiro - Reply
Do you offer a replacement kickstand for the surface rt 2?
allie - Reply
Does this replacement kickstand come with the screws also?
Andrea Thompson - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 40,584
