Microsoft Lumia 640 LTE Screen Replacement
  1. Microsoft Lumia 640 LTE Screen Replacement, Back Cover: step 1, image 1 of 2 Microsoft Lumia 640 LTE Screen Replacement, Back Cover: step 1, image 2 of 2
    • Use your thumb or fingernail on the edge/corner of the phone to pry the back cover off the phone.
  2. Microsoft Lumia 640 LTE Screen Replacement, Screen: step 2, image 1 of 3 Microsoft Lumia 640 LTE Screen Replacement, Screen: step 2, image 2 of 3 Microsoft Lumia 640 LTE Screen Replacement, Screen: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to pull back the sticker, revealing the screw underneath.
    • Be careful when removing the screws as they can strip easily.
  3. Microsoft Lumia 640 LTE Screen Replacement: step 3, image 1 of 2 Microsoft Lumia 640 LTE Screen Replacement: step 3, image 2 of 2
    • Use a T4 Torx driver to remove the screws in the four corners, along with the two in the middle left side (six total).
  4. Microsoft Lumia 640 LTE Screen Replacement: step 4, image 1 of 2 Microsoft Lumia 640 LTE Screen Replacement: step 4, image 2 of 2
    • Using the T4 Torx driver, unscrew the two screws.
    • Keep these screws separate from the screws from back of the phone to ensure that the right screws go where they belong.
  5. Microsoft Lumia 640 LTE Screen Replacement: step 5, image 1 of 2 Microsoft Lumia 640 LTE Screen Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to separate the screen from the back plastic casing
    • Use tweezers to release the clip on the side of device, and remove the back of the phone.
  6. Microsoft Lumia 640 LTE Screen Replacement: step 6, image 1 of 2 Microsoft Lumia 640 LTE Screen Replacement: step 6, image 2 of 2
    • Using the tweezers or a spudger, pull the gold tab up gently.
    • Using tweezers or a spudger, lift the white connector up gently to completely detach the screen from the phone.
    • For motherboard replacement, skip to Step 11 after finishing this step.
  7. Microsoft Lumia 640 LTE Screen Replacement: step 7, image 1 of 3 Microsoft Lumia 640 LTE Screen Replacement: step 7, image 2 of 3 Microsoft Lumia 640 LTE Screen Replacement: step 7, image 3 of 3
    • Using a plastic opening tool to carefully get under the gold strip.
    • Use tweezers to pull up the camera.
    • Use tweezers to pull up on the depth sensor.
    • This is held in by a strong adhesive.
  8. Microsoft Lumia 640 LTE Screen Replacement: step 8, image 1 of 1
    • Use a plastic opening tool to pry up the ear speaker.
    • This is held in by strong adhesive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 882
