Merch Source Projector Entertainment II Light Bulb Replacement
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: step 1, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: step 1, image 2 of 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: step 2, image 1 of 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: step 3, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement: step 3, image 2 of 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 1 of 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 2 of 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 3 of 3
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: step 5, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: step 5, image 2 of 2
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
Stephanie
276 Reputation
3 Guides authored
Cal Poly, Team 18-3, Maness Winter 2015 Member of Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Members
4 Guides authored
One Comment
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,857
