Mercedes-Benz c230 2007 Pull Handle Replacement
  1. Mercedes-Benz c230 2007 Pull Handle Replacement, Pull Handle: step 1, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement, Pull Handle: step 1, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement, Pull Handle: step 1, image 3 of 3
    • Use a spudger to pry off the cover of the pull handle.
    • Make sure to lower the window before starting the replacement. In my example, I do it during STEP 4.
  2. Mercedes-Benz c230 2007 Pull Handle Replacement: step 2, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 2, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 2, image 3 of 3
    • Use a spudger to pry off the SRS Airbag Badge.
  3. Mercedes-Benz c230 2007 Pull Handle Replacement: step 3, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 3, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 3, image 3 of 3
  4. Mercedes-Benz c230 2007 Pull Handle Replacement: step 4, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 4, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 4, image 3 of 3
    • Use the Door Upholstery Remover to pry off the door panel from the metal door frame.
    • After separating the door panel from the metal, gently pull the door panel away from the metal door frame from the sides and bottom to loosen the nails.
    • It would help if the window was down. After opening the window, make sure the car is turned off.
  5. Mercedes-Benz c230 2007 Pull Handle Replacement: step 5, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 5, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 5, image 3 of 3
    • Pull the rubber off the wire of the door handle latch cable.
    • Pull off from fasten.
    • Unhook the door handle latch cable
    • BEFORE TOUCHING THE INSIDE OF THE DOOR PANEL, MAKE SURE THE CAR IS TURNED OFF.
  6. Mercedes-Benz c230 2007 Pull Handle Replacement: step 6, image 1 of 2 Mercedes-Benz c230 2007 Pull Handle Replacement: step 6, image 2 of 2
  7. Mercedes-Benz c230 2007 Pull Handle Replacement: step 7, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 7, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 7, image 3 of 3
    • Use Flathead 3/32" or 2.5 mm Screwdriver to press the clips on the side of the pull handle piece.
    • This part of the pull handle is most likely going to be your broken piece, but if not, the piece you will be removing is the top of the pull handle.
    • These are the clips.
  8. Mercedes-Benz c230 2007 Pull Handle Replacement: step 8, image 1 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 8, image 2 of 3 Mercedes-Benz c230 2007 Pull Handle Replacement: step 8, image 3 of 3
Jesse Saroca
187 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 25
Past 30 Days: 117
All Time: 454
