Memorex CD Alarm Clock Radio PCB Board Replacement
  1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: step 1, image 1 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: step 1, image 2 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: step 1, image 3 of 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio PCB Board Replacement: step 2, image 1 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement: step 2, image 2 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement: step 2, image 3 of 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio PCB Board Replacement, PCB Board: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
    • Using a magnetic tip screwdriver will prevent screw loss.
  4. Memorex CD Alarm Clock Radio PCB Board Replacement: step 4, image 1 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement: step 4, image 2 of 3 Memorex CD Alarm Clock Radio PCB Board Replacement: step 4, image 3 of 3
    • Locate the wiring harness.
    • Disconnect the wiring harness using the tweezers.
  5. Memorex CD Alarm Clock Radio PCB Board Replacement: step 5, image 1 of 1
    • Remove the PCB board from the device.
    • Replace the broken motherboard with a new PCB board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 334
