Memorex CD Alarm Clock Radio Antenna Replacement
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: step 1, image 1 of 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: step 1, image 2 of 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: step 1, image 3 of 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: step 2, image 1 of 3 Memorex CD Alarm Clock Radio Antenna Replacement: step 2, image 2 of 3 Memorex CD Alarm Clock Radio Antenna Replacement: step 2, image 3 of 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: step 3, image 1 of 1
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 18
All Time: 780
