Matsunichi M97 9 inch Motherboard Replacement
  1. Matsunichi M97 9 inch Motherboard Replacement, Battery: step 1, image 1 of 1
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Motherboard Replacement: step 2, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Motherboard Replacement: step 3, image 1 of 3 Matsunichi M97 9 inch Motherboard Replacement: step 3, image 2 of 3 Matsunichi M97 9 inch Motherboard Replacement: step 3, image 3 of 3
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Motherboard Replacement: step 4, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Motherboard Replacement: step 5, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 5, image 2 of 2
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Motherboard Replacement, Motherboard: step 6, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Motherboard Replacement: step 7, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 7, image 2 of 2
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Motherboard Replacement: step 8, image 1 of 1
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Motherboard Replacement: step 9, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 9, image 2 of 2
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Motherboard Replacement: step 10, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 10, image 2 of 2
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Motherboard Replacement: step 11, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 11, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Motherboard Replacement: step 12, image 1 of 1
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Motherboard Replacement: step 13, image 1 of 2 Matsunichi M97 9 inch Motherboard Replacement: step 13, image 2 of 2
    • Lift the motherboard off the frame.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 101
