Marshall Emberton Button Replacement
  1. Marshall Emberton Button Replacement, Button: step 1, image 1 of 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Button Replacement: step 2, image 1 of 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
  3. Marshall Emberton Button Replacement: step 3, image 1 of 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
  4. Marshall Emberton Button Replacement: step 4, image 1 of 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
  5. Marshall Emberton Button Replacement: step 5, image 1 of 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
Asia Baldwin
697 Reputation
5 Guides authored
3 Comments
where can i find a replacement button
MANU 1907 - Reply
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Reply
yes, i confirme !!!
Mallet Jp -
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 77
All Time: 1,149
