Makita Jack Hammer HM1203C 2010 Bolt Service
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the side handle: step 1, image 1 of 1
    • Unscrew the knob securing the side handle.
  2. Makita Jack Hammer HM1203C 2010 Bolt Service: step 2, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 2, image 2 of 2
    • Remove the bolt securing the side handle.
    • Remove the side handle.
  3. Makita Jack Hammer HM1203C 2010 Bolt Service, Disassemble the front end: step 3, image 1 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service, Disassemble the front end: step 3, image 2 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service, Disassemble the front end: step 3, image 3 of 3
    • Use a small pry bar or flathead screwdriver to pry the rubber front cap off of the hammer.
    • This can be replaced as part of a service kit.
  4. Makita Jack Hammer HM1203C 2010 Bolt Service: step 4, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 4, image 2 of 2
    • Use a pair of snap ring pliers to expand the snap ring on the front of the hammer.
    • Remove the snap ring.
  5. Makita Jack Hammer HM1203C 2010 Bolt Service: step 5, image 1 of 1
    • Remove the washer on the front of the hammer.
  6. Makita Jack Hammer HM1203C 2010 Bolt Service: step 6, image 1 of 1
    • Lift the front cover off of the front of the hammer.
  7. Makita Jack Hammer HM1203C 2010 Bolt Service: step 7, image 1 of 1
    • Lift the rubber ring off of the front of the hammer.
  8. Makita Jack Hammer HM1203C 2010 Bolt Service: step 8, image 1 of 1
    • Remove the inner front cover.
  9. Makita Jack Hammer HM1203C 2010 Bolt Service: step 9, image 1 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service: step 9, image 2 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service: step 9, image 3 of 3
    • Compress the spring and hold it down while you pull the two retainers out of their slots and remove them.
  10. Makita Jack Hammer HM1203C 2010 Bolt Service: step 10, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 10, image 2 of 2
    • Remove the spring guide.
    • Remove the spring.
  11. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the barrel: step 11, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the barrel: step 11, image 2 of 2
    • Remove the front barrel cover.
  12. Makita Jack Hammer HM1203C 2010 Bolt Service: step 12, image 1 of 1
    • Remove the 4 mm hex bolt securing the barrel cover.
  13. Makita Jack Hammer HM1203C 2010 Bolt Service: step 13, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 13, image 2 of 2
    • Lift the barrel cover straight up and remove it.
  14. Makita Jack Hammer HM1203C 2010 Bolt Service: step 14, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 14, image 2 of 2
    • Use a pair of snap ring pliers to expand the snap ring securing the bolt holder.
  15. Makita Jack Hammer HM1203C 2010 Bolt Service: step 15, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 15, image 2 of 2
    • Lift the washer off of the bolt holder and remove it.
  16. Makita Jack Hammer HM1203C 2010 Bolt Service: step 16, image 1 of 1
    • Remove four 6 mm hex bolts securing the barrel.
  17. Makita Jack Hammer HM1203C 2010 Bolt Service: step 17, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 17, image 2 of 2
    • Lift the barrel straight up and remove it.
  18. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the rubber ring 39: step 18, image 1 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the rubber ring 39: step 18, image 2 of 3 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the rubber ring 39: step 18, image 3 of 3
    • Use an angled pick to pull the washer and rubber ring 39 out of the barrel.
  19. Makita Jack Hammer HM1203C 2010 Bolt Service: step 19, image 1 of 1
    • Remove the rubber ring 39.
  20. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the bolt holder: step 20, image 1 of 1
    • Lift the upper-most rubber ring straight up and remove it from the bolt holder.
  21. Makita Jack Hammer HM1203C 2010 Bolt Service: step 21, image 1 of 1
    • Lift the upper-most washer straight up and off of the bolt holder.
  22. Makita Jack Hammer HM1203C 2010 Bolt Service: step 22, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 22, image 2 of 2
    • Grasp the bolt holder, rubber ring 24, and the two metal sleeves below it, and lift it off of the cylinder.
  23. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove rubber ring 24: step 23, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove rubber ring 24: step 23, image 2 of 2
    • Separate the rubber ring 24 and the two metal sleeves from the bolt holder.
  24. Makita Jack Hammer HM1203C 2010 Bolt Service: step 24, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service: step 24, image 2 of 2
    • Separate the rubber ring 24 from the two metal sleeves.
    • Remove the rubber ring 24.
  25. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the O-ring 35.5: step 25, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the O-ring 35.5: step 25, image 2 of 2
    • Use an angled pick to lift the O-ring 35.5 out of its groove on the bolt holder.
    • Remove the O-ring 35.5.
  26. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the bolt: step 26, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the bolt: step 26, image 2 of 2
    • Use a long punch, long flathead screwdriver, or a thin, long bar to push the bolt out of the bolt holder.
    • Remove the bolt.
    • During reassembly, make sure all the seals on the bolt stay seated properly while you slide the bolt back into the holder.
  27. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the X-ring 21: step 27, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the X-ring 21: step 27, image 2 of 2
    • Use an angled pick to pry the X-ring 21 out of its groove in the bolt.
    • Remove the X-ring 21.
  28. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the fluoride ring 28: step 28, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the fluoride ring 28: step 28, image 2 of 2
    • Use an angled pick to pry the fluoride ring 28 out of its groove in the bolt.
    • Remove the fluoride ring 28.
  29. Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the O-ring 23: step 29, image 1 of 2 Makita Jack Hammer HM1203C 2010 Bolt Service, Remove the O-ring 23: step 29, image 2 of 2
    • Use an angled pick to pry the O-ring 23 out of its groove in the bolt.
    • Remove the O-ring 23.
Adam O'Camb
197,478 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 24
