Makita Jack Hammer HM1203C 2010 Barrel Service
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the side handle: step 1, image 1 of 1
    • Unscrew the knob securing the side handle.
  2. Makita Jack Hammer HM1203C 2010 Barrel Service: step 2, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 2, image 2 of 2
    • Remove the bolt securing the side handle.
    • Remove the side handle.
  3. Makita Jack Hammer HM1203C 2010 Barrel Service, Disassemble the front end: step 3, image 1 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service, Disassemble the front end: step 3, image 2 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service, Disassemble the front end: step 3, image 3 of 3
    • Use a small pry bar or flathead screwdriver to pry the rubber front cap off of the hammer.
    • This can be replaced as part of a service kit.
  4. Makita Jack Hammer HM1203C 2010 Barrel Service: step 4, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 4, image 2 of 2
    • Use a pair of snap ring pliers to expand the snap ring on the front of the hammer.
    • Remove the snap ring.
  5. Makita Jack Hammer HM1203C 2010 Barrel Service: step 5, image 1 of 1
    • Remove the washer on the front of the hammer.
  6. Makita Jack Hammer HM1203C 2010 Barrel Service: step 6, image 1 of 1
    • Lift the front cover off of the front of the hammer.
  7. Makita Jack Hammer HM1203C 2010 Barrel Service: step 7, image 1 of 1
    • Lift the rubber ring off of the front of the hammer.
  8. Makita Jack Hammer HM1203C 2010 Barrel Service: step 8, image 1 of 1
    • Remove the inner front cover.
  9. Makita Jack Hammer HM1203C 2010 Barrel Service: step 9, image 1 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service: step 9, image 2 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service: step 9, image 3 of 3
    • Compress the spring and hold it down while you pull the two retainers out of their slots and remove them.
  10. Makita Jack Hammer HM1203C 2010 Barrel Service: step 10, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 10, image 2 of 2
    • Remove the spring guide.
    • Remove the spring.
  11. Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the barrel: step 11, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the barrel: step 11, image 2 of 2
    • Remove the front barrel cover.
  12. Makita Jack Hammer HM1203C 2010 Barrel Service: step 12, image 1 of 1
    • Remove the 4 mm hex bolt securing the barrel cover.
  13. Makita Jack Hammer HM1203C 2010 Barrel Service: step 13, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 13, image 2 of 2
    • Lift the barrel cover straight up and remove it.
  14. Makita Jack Hammer HM1203C 2010 Barrel Service: step 14, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 14, image 2 of 2
    • Use a pair of snap ring pliers to expand the snap ring securing the bolt holder.
  15. Makita Jack Hammer HM1203C 2010 Barrel Service: step 15, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 15, image 2 of 2
    • Lift the washer off of the bolt holder and remove it.
  16. Makita Jack Hammer HM1203C 2010 Barrel Service: step 16, image 1 of 1
    • Remove four 6 mm hex bolts securing the barrel.
  17. Makita Jack Hammer HM1203C 2010 Barrel Service: step 17, image 1 of 2 Makita Jack Hammer HM1203C 2010 Barrel Service: step 17, image 2 of 2
    • Lift the barrel straight up and remove it.
  18. Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the rubber ring 39: step 18, image 1 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the rubber ring 39: step 18, image 2 of 3 Makita Jack Hammer HM1203C 2010 Barrel Service, Remove the rubber ring 39: step 18, image 3 of 3
    • Use an angled pick to pull the washer and rubber ring 39 out of the barrel.
  19. Makita Jack Hammer HM1203C 2010 Barrel Service: step 19, image 1 of 1
    • Remove the rubber ring 39.
Adam O'Camb
197,111 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 19
