Mad Catz Dual Force 2 Pro Vibration Motors Replacement
  1. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove Cover: step 1, image 1 of 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: step 2, image 1 of 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: step 3, image 1 of 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: step 4, image 1 of 2 Mad Catz Dual Force 2 Pro Vibration Motors Replacement: step 4, image 2 of 2
    • Grip the sides of the motor you wish to replace and lift up.
    • Be careful not to tear the wires that connect the motors to the motherboard.
  5. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove the Screw: step 5, image 1 of 1
    • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
    • If you do not know how to solder, see the soldering guide for instructions.
    • The positive (red) wire connects nearest the edge of the motherboard.
    • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
  6. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: step 6, image 1 of 1
    • If needed, repeat the last two steps for the other vibration motors.
Alexander Coyne
658 Reputation
5 Guides authored
USF Tampa, Team 7-2, Remmell Winter 2015 Member of USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 339
