Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement
  1. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement, Remove Cover: step 1, image 1 of 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: step 2, image 1 of 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: step 3, image 1 of 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: step 4, image 1 of 2 Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: step 4, image 2 of 2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: step 5, image 1 of 1
    • Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Pull the analog stick from the smaller circuit board.
2 other people completed this guide.
Alexander Coyne
658 Reputation
5 Guides authored
USF Tampa, Team 7-2, Remmell Winter 2015 Member of USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 41
All Time: 661
