Macintosh IIsi Hard Drive Replacement
  1. Macintosh IIsi Hard Drive Replacement, Top Case: step 1, image 1 of 2 Macintosh IIsi Hard Drive Replacement, Top Case: step 1, image 2 of 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: step 2, image 1 of 3 Macintosh IIsi Hard Drive Replacement: step 2, image 2 of 3 Macintosh IIsi Hard Drive Replacement: step 2, image 3 of 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: step 4, image 1 of 3 Macintosh IIsi Hard Drive Replacement: step 4, image 2 of 3 Macintosh IIsi Hard Drive Replacement: step 4, image 3 of 3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
4 other people completed this guide.
Chris Green
36,978 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,532 Guides authored
2 Comments
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Reply
Is there a way to read the HDD on a PC?
Charles - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,950
