Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement
  1. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Prepare your MacBook for disassembly: step 1, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Prepare your MacBook for disassembly: step 1, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Prepare your MacBook for disassembly: step 1, image 3 of 3
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the lower case: step 2, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the lower case: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unclip the lower case: step 3, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unclip the lower case: step 3, image 2 of 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  4. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the right clips: step 4, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the right clips: step 4, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the right clips: step 4, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the left clips: step 5, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the left clips: step 5, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the left clips: step 5, image 3 of 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the sliding clips: step 6, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the sliding clips: step 6, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Release the sliding clips: step 6, image 3 of 3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  7. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the lower case: step 7, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the lower case: step 7, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the lower case: step 7, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  8. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery board: step 8, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery board: step 8, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery board: step 8, image 3 of 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  9. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 9, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 9, image 2 of 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  10. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 10, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 10, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  11. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the trackpad cable bracket: step 11, image 1 of 1
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
  12. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the trackpad cable bracket: step 12, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the trackpad cable bracket: step 12, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  13. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the trackpad cable: step 13, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the trackpad cable: step 13, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Reposition the trackpad cable: step 14, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Reposition the trackpad cable: step 14, image 2 of 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  15. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery board: step 15, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery board: step 15, image 2 of 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  16. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 16, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 16, image 2 of 2
  17. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 17, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 17, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  18. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the data cable: step 18, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the data cable: step 18, image 2 of 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  19. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the battery connector: step 19, image 1 of 1
    • Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
  20. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery connector: step 20, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery connector: step 20, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Disconnect the battery connector: step 20, image 3 of 3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  21. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the trackpad: step 21, image 1 of 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Unfasten the trackpad: step 21, image 2 of 2
    • Use a T5 Torx driver to remove the ten 5.7 mm screws securing the trackpad:
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  22. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the trackpad: step 22, image 1 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the trackpad: step 22, image 2 of 3 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement, Remove the trackpad: step 22, image 3 of 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad should separate and lay flat on the display.
    • As you remove the trackpad, be very careful not to lose the six small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  23. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Trackpad Replacement: step 23, image 1 of 1
    • Remove the trackpad.
    • During reassembly:
    • Make sure your new trackpad has a ribbon cable installed. If necessary, transfer the old cable, or install the one your new trackpad came with.
    • Make sure that each of the six washers are present before you install the trackpad.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" Late 2023 (M3 Pro and M3 Max) Answers community for help.
Alex Diaz-Kokaisl
125,751 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 236
