Image #1 Image #2
Add Note Edit Step 9  ¶
  • Remove the following three screws securing the fan to the upper case:
    • One 7.1 mm Phillips screw.
    • Two 5 mm Phillips screws.
  • Lift the fan out of the upper case.
Image #1
Add Note Edit Step 10  ¶
  • Use the flat end of a spudger to pry the rear speaker connector up off the logic board.
  • This connector is very delicate and easily broken.
Image #1
Add Note Edit Step 11  ¶
  • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Use a spudger to pry the right speaker connector and sleep LED connector up off the logic board.
  • These connectors are very delicate and easily broken.
Image #1
Add Note Edit Step 13  ¶
  • Use the flat end of a spudger to pry the trackpad ribbon cable connector up off the logic board.
Image #1 Image #2
Add Note Edit Step 14  ¶
  • Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable.
  • Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
Image #1
Add Note Edit Step 15  ¶
  • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • Use a spudger to pry the left speaker connector and microphone connector up off the logic board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
