MacBook Pro 17" Unibody Logic Board Replacement
Completely replace the logic board on your MacBook Pro 17" Unibody.
  • Add Note x
  • x 4
Use this guide to replace your MacBook Pro's logic board. Before reattaching the heat sink, it is essential to apply a new layer of thermal paste.
Sections
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case.
  • Remove the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery  ¶
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Pull the tab parallel to the face of the logic board.
Next » « Previous
