Page 1 of 1
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Optical Drive Replacement
Replace the optical drive in your MacBook Pro 17" Models A1151 A1212 A1229 and A1261.
- Author: iRobot
- Difficulty: Moderate
Upgrade or replace the SuperDrive.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Optical Drive 3 steps
- Optical Drive Replacement 4 steps
Tools
- View:
- Paginated
- Full width
Edit Step 9 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit Step 13 ¶
Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Edit Step 17 ¶
Rotate the drive and remove the single Phillips screw securing the mounting bracket to the right side of the optical drive.
If you purchased an optical drive without mounting brackets, simply transfer the three silver metal brackets and orange ribbon cable to your new optical drive.
This guide has been completed 25 times.
Page 1 of 1
