MacBook Pro 15" Unibody Mid 2010 Hard Drive Replacement
Replace your hard drive.
  • Add Note x
  • x 53
Upgrade your hard drive for more storage space!
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
Add Note Edit Step 3 — Battery  ¶
  • Remove the two 7.4 mm Y1 Tri-Wing screws securing the battery to the upper case.
  • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
  • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
first image
Add Note Edit Step 4  ¶
  • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-Wing screw.
  • Remove the last 7.4 mm Y1 Tri-Wing screw securing the battery to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
  • Do not try to completely remove the battery just yet.
first image
Add Note Edit Step 6  ¶
  • Tilt the battery away from the logic board enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
  • Pull the battery cable connector away from the center of the logic board.
first image
Add Note Edit Step 7 — Hard Drive  ¶
  • Remove two Phillips screws securing the hard drive bracket to the upper case.
  • These screws are captive to the hard drive bracket.
first image
Add Note Edit Step 8  ¶
  • Lift the the retaining bracket out of the upper case.
first image
Add Note Edit Step 9  ¶
  • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove the hard drive cable by pulling its connector straight away from the hard drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11 — Hard Drive Replacement  ¶
  • Remove two T6 Torx screws from each side of the hard drive (four screws total).
  • You'll need to transfer these screws to your new hard drive if you're changing drives.
  • If desired, peel the pull tab off your old hard drive and transfer it to the side of your new drive.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
For more information, check out the MacBook Pro 15" Unibody Mid 2010 device page.
Did you successfully follow this guide?
This guide has been completed 53 times.
