Page 1 of 1
MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement
Replace the optical drive in your MacBook Pro 15" Unibody Mid 2009.
- Author: Andrew Bookholt
- Difficulty: Moderate
MacBook Pro won't read disks? Use this guide to replace a broken optical drive.
Sections
- Lower Case 2 steps
- Battery 4 steps
- Optical Drive 9 steps
- Optical Drive Replacement 1 step
Tools
- View:
- Paginated
- Full width
Edit Step 3
Battery
Three special five-point Torx screws secure the battery to the upper case.
Use Apple specialty tool 922-9101 or iFixit's 5-point Torx driver to remove the two exposed five-point Torx security screws along the top edge of the battery.
A common 1.5 mm flathead screwdriver also works well enough to remove the screws.
You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
Edit Step 7
Optical Drive
Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Edit Step 10 ¶
This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Pull the connector parallel to the face of the logic board, not straight up.
Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Edit Step 11 ¶
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
Lift the Bluetooth board/cable retainer assembly out of the upper case.
Edit Step 16
Remove the optical drive cable by pulling it straight away from the optical drive.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
This guide has been completed 12 times.
Page 1 of 1
