View profile
Order History
Logout
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$12.95 · 50+ in stock
$99.95 · 9 in stock
$129.95 · 23 in stock
$24.95 · 22 in stock
$7.95 · 16 in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$9.95 · 50+ in stock
« Previous
Next »
Page 2 of 4
Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Torx screw hidden underneath.
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
Do not try to completely remove the battery just yet.
Tilt the battery back enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Next » « Previous
1024
