Page 1 of 1
MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement
- Author: iRobot
- Difficulty: Moderate
The ins and outs of replacing your upper case.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Edit
Step 31
Disconnect the Bluetooth data cable from the upper case.
Lift the Bluetooth board and attached cable off the upper case.
Upper case remains.
To install your replacement upper case, install your current Bluetooth board, antenna, and keyboard into the replacement case and reassemble your computer.
This guide has been completed 3 times.
Page 1 of 1
