Page 1 of 1
MacBook Pro 13" Unibody Mid 2010 Hard Drive Replacement
Replace or upgrade the hard drive on your MacBook Pro 13" Unibody Mid 2010.
- Author: Walter Galan
- Difficulty: Moderate
Upgrade your hard drive for more storage capacity!
- View:
- Paginated
- Full width
Edit Step 3
Battery
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Edit Step 8
Remove the two T6 Torx screws from each side of the hard drive (four screws total).
You'll need to transfer these screws to your new hard drive if you're changing drives.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
This guide has been completed 75 times.
Page 1 of 1
