first image
Add Note Edit Step 7  ¶
  • Remove the hard drive cable by pulling its connector straight away from the hard drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8 — Hard Drive Replacement  ¶
  • Remove the two T6 Torx screws from each side of the hard drive (four screws total).
  • You'll need to transfer these screws to your new hard drive if you're changing drives.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Next » « Previous
For more information, check out the MacBook Pro 13" Unibody Mid 2009 device page.
Did you successfully follow this guide?
This guide has been completed 132 times.
