MacBook Air Models A1237 and A1304 Audio Board Replacement
  • Add Note x
  • x 5
Regain the function of your speakers by replacing the audio board.
Sections
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
Add Note Edit Step 6 — Speaker  ¶
  • Remove the following two screws securing the speaker assembly to the upper case.
    • One 3 mm Phillips.
    • One 5.8 mm Phillips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
  • Disconnect the audio out connector from its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Rotate the speaker assembly toward the center of the Air.
  • Use a spudger to pry the speaker cable connector up off the audio board.
first image
Add Note Edit Step 9 — Audio Board Replacement  ¶
  • Use the pointed end of a spudger to pry the speaker connector up off the audio board.
first image
Add Note Edit Step 10  ¶
  • Insert the pointed end of a spudger into the gap around the audio board to pry it up off the adhesive securing it to the speaker housing.
first image
Add Note Edit Step 11  ¶
  • Disconnect the audio out cable by pulling its connector straight away from the socket on the audio board.
first image
Add Note Edit Step 12  ¶
  • Audio board remains.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
This guide has been completed 5 times.
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Related Products
MacBook Air (Original) Audio Board
$79.95 · 6 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
