MacBook Unibody Model A1342 Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Unibody Model A1342 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
  2. MacBook Unibody Model A1342 Optical Drive Replacement: step 2, image 1 of 1
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
    • This screw is located in a gap within the right speaker assembly, and is visible only from the hinge edge.
  3. MacBook Unibody Model A1342 Optical Drive Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  4. MacBook Unibody Model A1342 Optical Drive Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the rear speaker connector up off the logic board.
    • Pry up underneath the wires.
    • This connector is very delicate and easily broken.
  5. MacBook Unibody Model A1342 Optical Drive Replacement: step 5, image 1 of 1
    • Carefully rotate the rear speaker assembly (with AirPort/Antenna cables still attached) out of the lower case.
  6. MacBook Unibody Model A1342 Optical Drive Replacement: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  7. MacBook Unibody Model A1342 Optical Drive Replacement: step 7, image 1 of 1
    • Remove the single 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
  8. MacBook Unibody Model A1342 Optical Drive Replacement: step 8, image 1 of 1
    • Remove the two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  9. MacBook Unibody Model A1342 Optical Drive Replacement: step 9, image 1 of 1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 813
