MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement, Hard Drive Removal/Installation: step 1, image 1 of 1
    • Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • The bottom left three screws are longer. Set those aside for reassembly
  2. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: step 2, image 1 of 1
    • Here are the three larger screws. The smaller ones fit the remaining holes
  3. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: step 3, image 1 of 1
    • Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
    • Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
19 other people completed this guide.
jgreenmun
876 Reputation
1 Guide authored
One Comment
do you know if it's posible to upgrade the RAM memory in this particular model ?
Thanks for the guide,
Fons - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 14,537
