MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement
  • Add Note x
  • x 95
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
Image #1 Image #2
Add Note Edit Step 1 — Access Door  ¶
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Image #1
Add Note Edit Step 2  ¶
  • The access door should now be raised enough to lift it up and out of the Unibody.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
  • If the latch is depressed it will lock the battery in place.
Image #1
Add Note Edit Step 4 — Hard Drive  ¶
  • Remove the single Phillips screw securing the hard drive bracket to the upper case.
  • This screw is captive to the hard drive bracket.
Image #1
Add Note Edit Step 5  ¶
  • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
  • Lift the hard drive out of the upper case, minding the cable attaching it to the computer.
Image #1
Add Note Edit Step 6  ¶
  • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
Image #1
Add Note Edit Step 7 — Hard Drive Replacement  ¶
  • Remove two T6 Torx screws from each side of the hard drive (four screws total).
  • You'll need to transfer these screws to your new hard drive if you're changing drives.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 21 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
