MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement, Trackpad: step 1, image 1 of 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 2, image 1 of 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 3, image 1 of 1
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  5. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 5, image 1 of 1
    • Lift the battery out of the upper case
  6. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 6, image 1 of 2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 6, image 2 of 2
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  7. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 7, image 1 of 2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: step 7, image 2 of 2
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
8 other people completed this guide.
SIMRAN
6,363 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
321 Members
1,464 Guides authored
2 Comments
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - Reply
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 16
All Time: 19,740
