Image #1
Add Note Edit Step 9  ¶
  • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Image #1
Add Note Edit Step 10  ¶
  • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
  • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
  • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
Image #1 Image #2 Image #3
Add Note Edit Step 11  ¶
  • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
Add Note Edit Step 12  ¶
  • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
  • Use your spudger to slide the keyboard ribbon cable out of its socket.
Image #1
Add Note Edit Step 13  ¶
  • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Add Note Edit Step 14  ¶
  • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
  • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Image #1
Add Note Edit Step 15  ¶
  • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
Image #1
Add Note Edit Step 16  ¶
  • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 10 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
