Image #1
Add Note Edit Step 25 — Optical Drive  ¶
  • Remove the hard drive from the mini, minding any cables that may get caught.
Image #1
Add Note Edit Step 26  ¶
  • Remove the 7.9 mm T6 Torx screw securing the optical drive to the outer case.
Image #1
Add Note Edit Step 27  ¶
  • Slide the optical drive out of the outer case, minding any cables that may get caught.
Image #1
Add Note Edit Step 28 — Optical Drive Replacement  ¶
  • Carefully de-route the IR sensor cables from the channel in the optical drive bracket.
Image #1 Image #2
Add Note Edit Step 29  ¶
  • Remove the two 6.3 mm T6 Torx screws securing both sides of the optical drive bracket to the optical drive (four screws total).
Image #1
Add Note Edit Step 30  ¶
  • Remove the optical drive bracket from the optical drive, minding any cables that may get caught.
Image #1
Add Note Edit Step 31  ¶
  • Carefully peel the optical drive ribbon cable off the body of the optical drive.
Image #1
Add Note Edit Step 32  ¶
  • Disconnect the optical drive cable by pulling its connector away from the body of the optical drive.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Mac Mini Logic Board Removal Tool
$4.95 · 30 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
T5 Torx Screwdriver
Anti-Static Wrist Strap
$7.95 · 50+ In stock
Thirsty Bag
$9.95 · 50+ In stock
