Image #1 Image #2
Add Note Edit Step 9  ¶
  • Slightly lift the antenna plate from the end closest to the RAM.
  • Carefully pull the antenna plate straight away from the circular rim of the outer case.
  • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
Image #1
Add Note Edit Step 10  ¶
  • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
Image #1
Add Note Edit Step 11  ¶
  • Remove the antenna plate from the mini.
Image #1
Add Note Edit Step 12 — Logic Board  ¶
  • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
Image #1 Image #2
Add Note Edit Step 13  ¶
  • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
Image #1 Image #2
Add Note Edit Step 14  ¶
  • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
Image #1
Add Note Edit Step 15  ¶
  • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
Image #1
Add Note Edit Step 16  ¶
  • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 44 In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Mac Mini Logic Board Removal Tool
$4.95 · 31 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 16 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
iPhone 4S Display Assembly
$94.95 · 23 In stock
iPhone 3G Replacement Battery
$14.95 · 50+ In stock
