Page 1 of 1
Mac Mini Mid 2010 Logic Board Replacement
Completely replace your Mac Mini Mid 2010's logic board.
- Author: Andrew Bookholt
- Difficulty: Difficult
Completely replacing the logic board requires removal of the logic board itself as well as all components attached to it.
Sections
- Bottom Cover 2 steps
- Fan 3 steps
- Cowling 2 steps
- Antenna Plate 4 steps
- Logic Board 9 steps
- Speaker 2 steps
- I/O Bezel 7 steps
- Logic Board Replacement 9 steps
- View:
- Paginated
- Full width
Edit
Step 17
To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
Insert a Mac Mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac Mini Logic Board Removal tool.
Edit
Step 24
De-route both antenna cables from the clips securing them to the top side of the logic board.
Be careful when removing the cables from their retaining clips, as the thin metal contacts crimped to the antenna cables can be easily torn off. If any contacts become separated from the antenna cables, use a pair of pliers to gently crimp them back into place.
Edit
Step 29
Pull the I/O bezel away from the logic board, minding any cables that may get caught.
Try not to handle the small steel EMI fingers on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the EMI fingers to remove any oils transferred during the removal process.
Edit
Step 31
Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
After the RAM chip has popped up, pull it straight out of its socket.
Repeat this process if a second RAM chip is installed.
Edit
Step 38
Carefully lift the heat sink off the logic board, minding the thermal sensor cable that may get caught.
If the heat sink appears to be stuck to the logic board after removing all six screws, it may be helpful to use a spudger to separate the two components.
If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
This guide has been completed 2 times.
Page 1 of 1
