first image
Add Note Edit Step 4  ¶
  • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
first image
Add Note Edit Step 5  ¶
  • Lift the fan out of the mini for enough clearance to access its connector.
  • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
  • Remove the fan.
first image
Add Note Edit Step 6 — Cowling  ¶
  • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Next » « Previous
