Image #1
Add Note Edit Step 33  ¶
  • Peel off the strip of black tape covering the optical drive thermal sensor.
Image #1
Add Note Edit Step 34  ¶
  • Carefully pry the optical drive thermal sensor off the adhesive securing it to the optical drive.
  • It may be necessary to use a strip of tape or rubber cement to attach the thermal sensor to your new optical drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 39 In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 11 In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Mac Mini Logic Board Removal Tool
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
iPhone 4S Dock Connector
$34.95 · 16 In stock
iPad 3rd Gen Front Panel Assembly
$119.95 · 7 In stock
T6 Torx Screwdriver
$4.95 · 11 In stock
Metal Spudger
$2.95 · 1 In stock
26 Bit Driver Kit
$19.95 · 3 In stock
