MSI PE70 6QE-035US Battery Replacement
  1. MSI PE70 6QE-035US Battery Replacement, Battery: step 1, image 1 of 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US Battery Replacement: step 2, image 1 of 1
    • Now that the back panel has been removed, you will see the battery.
  3. MSI PE70 6QE-035US Battery Replacement: step 3, image 1 of 1
    • Use the PH0 bit to remove the screw.
    • You can now pull the battery out
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 22
All Time: 101
