MSI GS66 Stealth 11UE-007 Speakers Replacement
  1. MSI GS66 Stealth 11UE-007 Speakers Replacement, Battery: step 1, image 1 of 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device.
  2. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 2, image 1 of 1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 3, image 1 of 1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 4, image 1 of 1
    • Remove one 7 mm Phillips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 5, image 1 of 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 5, image 2 of 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 5, image 3 of 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 6, image 1 of 1
    • Peal back metallic tape on the right side of the USB port.
  7. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 7, image 1 of 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 7, image 2 of 2
    • Remove three 6 mm Phillips #1 screws.
  8. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 8, image 1 of 1
    • Use the tip of the spudger or your fingernail to gently push out the white connector.
  9. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 9, image 1 of 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 9, image 2 of 2
    • Remove the battery from the device.
  10. MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: step 10, image 1 of 2 MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: step 10, image 2 of 2
    • Disconnect the speaker power using the tip of the spudger or fingernail to gently push on either side of the connector.
  11. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 11, image 1 of 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 11, image 2 of 2
    • Lift up the clip using the spudger.
    • Pull out the ribbon cable away from the clips.
  12. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 12, image 1 of 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 12, image 2 of 2
    • Remove the wire from the channel it's sitting in.
  13. MSI GS66 Stealth 11UE-007 Speakers Replacement: step 13, image 1 of 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 13, image 2 of 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: step 13, image 3 of 3
    • Lift up the left and right speakers.
Alex Robinson
1,048 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 8
All Time: 88
