MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement
  1. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement, MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 1, image 1 of 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device for any outlet.
  2. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 2, image 1 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 2, image 2 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 2, image 3 of 3
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    • Remove eight 10mm Phillips J1 screws.
    • Remove one 7mm Philips J1 screw from the center bottom of backplate.
  3. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 3, image 1 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 3, image 2 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 3, image 3 of 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  4. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 4, image 1 of 2 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 4, image 2 of 2
    • Disconnect the wires from the cooling fan.
  5. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 5, image 1 of 2 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 5, image 2 of 2
    • Disconnect the two wires from the Wi-Fi card.
  6. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 6, image 1 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 6, image 2 of 3 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 6, image 3 of 3
    • Remove the nine 6 mm screws.
  7. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 7, image 1 of 2 MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 7, image 2 of 2
    • Remove the tape connecting the fans to the fan housing.
  8. MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: step 8, image 1 of 1
    • Lift up the cooling unit like it is hinged at the back.
    • Replace thermal paste.
Alex Robinson
1,048 Reputation
6 Guides authored
2 Comments
When putting the heatsink back on, do we only need to reapply cpu thermal paste, or do we have to replace the pink stuff? If so, what is the pink stuff, and where can I get it?
Alexandru - Reply
If you only have issues with thermals on your cpu then I would just replace the gray thermal paste directly on the cpu. The “pink stuff” is also thermal paste for the other components. It would normally have thermal pads but there must not have been enough room for them in the design.
Scott Brooks - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 308
