MSI GS60 6QE GHOST PRO 4K RAM Replacement
  1. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: step 1, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: step 1, image 2 of 2
    • Remove the eleven 5mm screws with a Phillips #0 bit.
    • Remove the four 2.5mm screws with a Phillips #0 bit.
  2. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 2, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 2, image 2 of 2
    • After opening the bottom plate, locate the battery and the battery connection.
  3. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 3, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 3, image 2 of 2
    • Unplug the battery connection carefully from the motherboard, and remove the old battery.
  4. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Motherboard: step 4, image 1 of 1
    • Remove the four 2.5 mm screws from the motherboard.
  5. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 5, image 1 of 1
    • Unplug the speaker wire.
  6. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 6, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 6, image 2 of 2
    • Gently lift the selected black tab that connects the cable onto the board and then slide out the cable.
    • Be careful not to break the black cover.
  7. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 7, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 7, image 2 of 2
    • Be careful not to break the black cover because it can be broken easily
  8. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 8, image 1 of 1
    • Be careful not to break the black cover. lift it up gently
  9. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 9, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 9, image 2 of 2
  10. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 10, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 10, image 2 of 2
  11. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 11, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 11, image 2 of 2
    • Unplug the selected cable
  12. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 12, image 1 of 3 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 12, image 2 of 3 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 12, image 3 of 3
    • Locate and unplug the selected cables.
  13. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 13, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 13, image 2 of 2
    • Unplug it carefully without breaking the black cover.
  14. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 14, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 14, image 2 of 2
    • Gently unplug the selected cable
  15. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 15, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 15, image 2 of 2
    • Gently remove the electronic component by sliding it out and lifting it up after unscrewing the 2.5 mm screw
    • Make sure your unscrew the screw first and unplug the chip from the motherboard. Do not disconnect the wires connected to the chip
  16. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 16, image 1 of 1
    • After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
    • This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
  17. MSI GS60 6QE GHOST PRO 4K RAM Replacement, RAM: step 17, image 1 of 1
    • After removing the motherboard from the laptop chassis locate the RAM chips indicated by the red rectangle.
  18. MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 18, image 1 of 2 MSI GS60 6QE GHOST PRO 4K RAM Replacement: step 18, image 2 of 2
    • Firmly grip the two rectangular Ram components, one at a time, and pull them up from the Motherboard, be gentle. Once this process is complete, you have successfully removed the Ram.
3 other people completed this guide.
Justin Pelley
161 Reputation
1 Guide authored
USF Tampa, Team S1-G4, Nance Fall 2017 Member of USF Tampa, Team S1-G4, Nance Fall 2017
USFT-NANCE-F17S1G4
3 Members
5 Guides authored
One Comment
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
Ondřej Kyzek - Reply
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 24
All Time: 2,969
