MSI GS60 6QE GHOST PRO 4K Motherboard Replacement
  1. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement, Battery: step 1, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement, Battery: step 1, image 2 of 2
    • Remove the eleven 5mm screws with a Phillips #0 bit.
    • Remove the four 2.5mm screws with a Phillips #0 bit.
  2. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 2, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 2, image 2 of 2
    • After opening the bottom plate, locate the battery and the battery connection.
  3. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 3, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 3, image 2 of 2
    • Unplug the battery connection carefully from the motherboard, and remove the old battery.
  4. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Remove the four 2.5 mm screws from the motherboard.
  5. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 5, image 1 of 1
    • Unplug the speaker wire.
  6. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 6, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 6, image 2 of 2
    • Gently lift the selected black tab that connects the cable onto the board and then slide out the cable.
    • Be careful not to break the black cover.
  7. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 7, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 7, image 2 of 2
    • Be careful not to break the black cover because it can be broken easily
  8. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 8, image 1 of 1
    • Be careful not to break the black cover. lift it up gently
  9. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 9, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 9, image 2 of 2
  10. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 10, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 10, image 2 of 2
  11. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 11, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 11, image 2 of 2
    • Unplug the selected cable
  12. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 12, image 1 of 3 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 12, image 2 of 3 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 12, image 3 of 3
    • Locate and unplug the selected cables.
  13. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 13, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 13, image 2 of 2
    • Unplug it carefully without breaking the black cover.
  14. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 14, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 14, image 2 of 2
    • Gently unplug the selected cable
  15. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 15, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 15, image 2 of 2
    • Gently remove the electronic component by sliding it out and lifting it up after unscrewing the 2.5 mm screw
    • Make sure your unscrew the screw first and unplug the chip from the motherboard. Do not disconnect the wires connected to the chip
  16. MSI GS60 6QE GHOST PRO 4K Motherboard Replacement: step 16, image 1 of 1
    • After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
    • This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
2 other people completed this guide.
Azher Hamid
378 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Nance Fall 2017 Member of USF Tampa, Team S1-G4, Nance Fall 2017
USFT-NANCE-F17S1G4
3 Members
5 Guides authored
2 Comments
Hello,
can you please submit us the mainboard version (V1.1 or V1.2) for the MSI GS60 Ghost Pro 4K Laptop?
i need a replacement but i dont know which version is the right one for my GS60 4K (MS-16H71)
thanks in advance
best regards
Sebastian U. - Reply
Hi,
Hi,
I was wondering if you could help me? I need to find a complete bottom section for my MSI GS60 2QEAs it has completely melted. If you could let me know of any possible suppliers I’ll be very grateful.
Stephen Donnelly - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 30
All Time: 4,480
