MSI GP60 2PE Leopard Fan Replacement
  1. MSI GP60 2PE Leopard Fan Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over so the back is facing up.
  2. MSI GP60 2PE Leopard Fan Replacement: step 2, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 2, image 2 of 2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  3. MSI GP60 2PE Leopard Fan Replacement: step 3, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 3, image 2 of 2
    • Once all four screws are removed, lift the back off.
  4. MSI GP60 2PE Leopard Fan Replacement, Fan: step 4, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement, Fan: step 4, image 2 of 2
    • Remove the three 5 mm screws from the fan with a Phillips #00 screwdriver.
  5. MSI GP60 2PE Leopard Fan Replacement: step 5, image 1 of 3 MSI GP60 2PE Leopard Fan Replacement: step 5, image 2 of 3 MSI GP60 2PE Leopard Fan Replacement: step 5, image 3 of 3
    • Pull the wire on the bottom left of the fan out of the socket.
    • Pull the wire gently; pulling too hard could damage the wire.
  6. MSI GP60 2PE Leopard Fan Replacement: step 6, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 6, image 2 of 2
    • Remove the fan.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,638
