MSI GE62 Apache Pro 004 Speakers Replacement
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: step 1, image 1 of 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: step 2, image 1 of 2 MSI GE62 Apache Pro 004 Speakers Replacement: step 2, image 2 of 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: step 3, image 1 of 3 MSI GE62 Apache Pro 004 Speakers Replacement: step 3, image 2 of 3 MSI GE62 Apache Pro 004 Speakers Replacement: step 3, image 3 of 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: step 4, image 1 of 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: step 4, image 2 of 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: step 4, image 3 of 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: step 5, image 1 of 2 MSI GE62 Apache Pro 004 Speakers Replacement: step 5, image 2 of 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Majid Al Hashmi
283 Reputation
2 Guides authored
USF Tampa, Team S15-G5, Boczar Spring 2018 Member of USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,503
