LifePrint 2x3 Motor-Feeder Replacement
  1. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: step 1, image 1 of 3 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: step 1, image 2 of 3 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: step 1, image 3 of 3
    • Make sure the top of the Lifeprint is facing upwards displaying the Lifeprint logo.
    • Slide open the top cover and remove the top lid.
  2. LifePrint 2x3 Motor-Feeder Replacement: step 2, image 1 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 2, image 2 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 2, image 3 of 3
    • Remove the six screws on the outer sides of the device with the Phillips #00 screwdriver.
    • The motor is highlighted in orange.
  3. LifePrint 2x3 Motor-Feeder Replacement: step 3, image 1 of 2 LifePrint 2x3 Motor-Feeder Replacement: step 3, image 2 of 2
    • After removing the six screws, gently flip the device over so the bottom cover is facing you.
    • Remove the bottom cover by using the opening pick.
  4. LifePrint 2x3 Motor-Feeder Replacement: step 4, image 1 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 4, image 2 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 4, image 3 of 3
    • Remove the four screws using the Phillips #00 screwdriver to access the motor and sensor (highlighted in orange).
  5. LifePrint 2x3 Motor-Feeder Replacement: step 5, image 1 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 5, image 2 of 3 LifePrint 2x3 Motor-Feeder Replacement: step 5, image 3 of 3
    • Remove the component holding the motor and feeder.
    • Using a spudger remove the top piece of the component to get to the motor and feeder.
    • Remove the motor and feeder assembly from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 250
