Lenovo Yoga 710-14IKB Back Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Lenovo Yoga 710-14IKB Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Back Cover Replacement: step 2, image 1 of 3 Lenovo Yoga 710-14IKB Back Cover Replacement: step 2, image 2 of 3 Lenovo Yoga 710-14IKB Back Cover Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
2 other people completed this guide.
Stephen DeHerrera
404 Reputation
1 Guide authored
Cal Poly, Team S14-G5, Banghart Spring 2017 Member of Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 181
