Lenovo ThinkPad X390 Yoga Touchpad Replacement
  1. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Back Case: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 3, image 1 of 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Battery: step 4, image 1 of 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 5, image 1 of 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 6, image 1 of 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Touchpad: step 7, image 1 of 1
    • Disconnect the touchpad ribbon connector from the motherboard using the opening tool.
  8. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 8, image 1 of 1
    • Remove the four 4 mm screws using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Touchpad Replacement: step 9, image 1 of 1
    • Carefully open the laptop and remove the touchpad.
Tanner Baine
423 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 697
