Introduction
This guide should help you with removing & replacing the Lenovo ThinkPad T530 hard drive (HDD) with a new one or a solid state Drive (SSD). This is a remarkably simple repair as the HDD is designed to be accessible.
You can find the official Lenovo documentation attached as well.
Place it on a flat, sturdy surface and unplug the power cord.
Remove the battery by moving the battery latch and sliding the battery out.
Locate the drive enclosure.
Use a small Philips screwdriver to unscrew the single screw that holds down the drive enclosure cover. Loosen the screw, but do not remove it.
Carefully remove the drive enclosure cover.
Attached Documents
2 Comments
Kann ich da auch eine mSATA SSD nachrüsten? Wenn ja, welche wären das?
The Service Manual (from Lenovo) says its possible to put in an mSata drive in the WWAN slot although they claim it should only be used as cache- as it isn't nearly as reliable. Below is a link to their documentation, flip to page 82.
