Lenovo ThinkPad T460 Wi-Fi Card Replacement
  1. Lenovo ThinkPad T460 Wi-Fi Card Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement, External Battery: step 1, image 3 of 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 2, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 2, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 2, image 3 of 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Wi-Fi Card Replacement, Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement, Bottom Cover: step 3, image 2 of 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 4, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 4, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 4, image 3 of 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 5, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 5, image 2 of 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 6, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 6, image 2 of 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 7, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 7, image 2 of 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 8, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 8, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 8, image 3 of 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Wi-Fi Card Replacement, Wi-Fi Card: step 9, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement, Wi-Fi Card: step 9, image 2 of 2
    • Use your fingers to lift up the black flap covering the Wi-Fi card.
  10. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 10, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 10, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 10, image 3 of 3
    • Use the flat end of a spudger to disconnect the gray and black coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the top and the black wire on the bottom.
  11. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 11, image 1 of 2 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 11, image 2 of 2
    • Remove the single 3.7 mm screw from the right side of the Wi-Fi card using a Phillips #1 screwdriver.
  12. Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 12, image 1 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 12, image 2 of 3 Lenovo ThinkPad T460 Wi-Fi Card Replacement: step 12, image 3 of 3
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
Kristen Gismondi
83,601 Reputation
205 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,680 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 1,484
